Is Laser Welding a Good Fit for Your Operation? | MillerWelds
Share
For companies looking to improve productivity and reduce costs in the welding operation, laser welding is one option to consider. Laser welding is more accessible and affordable than ever — offering much faster travel speeds than other welding processes and weld consistency in automated welding applications.
Laser welding offers fast travel speeds
Performarc Laser Welding Cell
laser welding
Improve productivity and save money
Finding ways to improve productivity and save money are important factors in any welding application. Companies often look at technology advancements to achieve these goals, but many operations might not consider laser welding — perhaps viewing it as too expensive or complicated.
Developments in laser welding technology have made it more accessible and affordable than ever. The process also offers significant productivity benefits that can deliver a fast return on investment. It’s especially well-suited for sheet metal welding applications.
Is laser welding right for your sheet metal operation? Consider these key factors and benefits.
Benefits of laser welding systems
Laser welding offers travel speeds that can be five to ten times faster than TIG welding and three to five times faster than MIG welding in some applications. It’s also a good alternative to resistance spot welding in many applications.
Automated welding of sheet metal is one example where a change to laser welding can offer significant productivity advantages. Because the laser welding process offers high travel speeds and low heat input, it helps prevent burn-through on this typically thin material.
There are also pre-engineered laser welding systems on the market that offer easy installation, so downtime for setup is minimal.
Laser welding advancements
The use of laser welding continues to grow in automated welding applications, due to advancements that have made the technology more accessible and affordable.
Laser welding uses a laser to join pieces of metal. Traditionally, high-powered lasers used carbon dioxide as the medium and had a wavelength of about 10 microns. A laser of this wavelength cannot be transmitted through a fiber optic cable, making it difficult to automate a laser welding process.
Technology advancements have moved the industry forward in this regard. The evolution of 1-micron wavelength lasers means that the laser can be transmitted through fiber optic cable, making lasers more easily automated for welding.
In addition, 1-micron wavelength lasers are typically powered by diodes. As manufacturers have become more adept at producing powerful diodes, fewer diodes are required to power these lasers. This continues to reduce the cost per power for laser welding systems.
Gaining advantages on sheet metal
Parts that operations traditionally TIG weld and that require a high-quality appearance are good candidates for conversion to a laser welding process. These factors make laser welding especially well-suited for sheet metal applications.
Sheet metal is typically very thin and requires a low heat input in welding. It’s also often used in applications that require high aesthetic quality or cosmetic results, such as appliances, signs or elevator panels. Laser welding can be a good solution to these needs.
In addition, laser welding sometimes doesn’t require the use of filler metal or shielding gas. This gives the weld a very low profile that doesn’t require grinding after completing the weld — saving time and money and helping to increase productivity in the operation.
For example, a common sheet metal application is the manufacture of electrical boxes. With MIG welding, it would typically require post-weld grinding to remove excess weld reinforcements at the outside corners. A switch to laser welding eliminates the time and money spent in post-weld cleanup.
And as previously mentioned, the much greater travel speeds of laser welding compared to TIG or MIG welding help companies improve productivity and efficiency, which can positively impact the bottom line.
Conduction vs. keyhole mode
There are two modes in laser welding: conduction and keyhole. Each type has benefits for specific applications, so be sure to consider which one might best suit your needs.
The welding system transitions between conduction and keyhole modes depending upon energy density.
At a lower energy density, the laser has a larger spot and a lower amount of power. This is conduction mode. In this mode, the surface is being heated, and the heat is transferring through the part via conduction. Conduction mode typically has a very calm puddle, similar to TIG welding, and works well for cosmetic welds that must be precise, such as the outside corners of boxes or signs.
As the power level increases — say a 2-millimeter spot shrinks to 0.6 millimeter in diameter — the energy density becomes much higher. This deeper penetration weld with more energy density is the keyhole mode.
Operations can use keyhole mode to pierce two pieces of material stacked on top of each other to produce a weld. When light from the laser hits the top surface, it vaporizes and penetrates through both pieces and fills in the weld as fast as the laser moves. This makes keyhole mode laser welding a good alternative in applications with stacked or overlapping materials that previously required a process like resistance spot welding. Keyhole mode laser welding is much more efficient than resistance spot welding, which uses two electrodes and requires access to the top and bottom sides of the material being welded. Resistance spot welding is also more difficult to automate.
Operations can use the same laser welding system for both conduction mode and keyhole mode. By increasing the power or making the spot size from the laser smaller, this changes the mode from conduction to keyhole.
Consider pre-engineered systems
Implementing a pre-engineered laser welding system can offer many benefits. Pre-engineered systems available on the market offer ease of use and fast and easy installation.
Some manufacturers build pre-engineered cells on a single platform and ship them pre-assembled. You can then drop them into your welding operation and get them up and running quickly, often the same day. This makes it as easy to integrate a laser welding cell in your operation as any other robotic welding system.
The main difference between a pre-engineered laser welding system and other pre-engineered robotic systems is that operations must contain all the light in the welding area for a laser system inside the unit for safety reasons. When a system that meets this requirement receives a class 1 rating, which means workers do not need extra eye protection outside the cell. This provides greater flexibility as to where operations can place a laser welding cell in the shop or on the factory floor.
Some welding system manufacturers also offer testing labs where sample parts can be processed in a laser welding system. This helps you determine if a laser system is right for your application.
Laser welding systems provide productivity gains
Laser welding is an unknown or unexplored option for many manufacturers with automated welding applications, but it is just as easy to implement as other robotic welding systems. The fast travel speeds and low heat input of laser welding makes it especially well-suited for sheet metal welding applications that require precision and attention to aesthetics.
For operations now using MIG, TIG or resistance spot welding, a switch to laser welding can significantly improve productivity — saving time and money while still producing high-quality welds.
Published:
