Proper Shielding Gas Coverage Is Key to Success in GTAW | MillerWelds
Best Practices For Proper Shielding Gas in TIG Welding
Share
Choosing a suitable TIG welding shielding gas does more than guarantee a high-quality weld; it could save you thousands in wasted gas costs and added rework.
Many factors impact shielding gas coverage, including choosing consumables paired with the proper gas flow settings, and this article will help you choose the right setup for your success.
Tig Welding
TIG Welding
Collet vs Gas Lenses
Gas Lens flow rate
Gas for TIG welding
When pinpoint control, high quality and aesthetics are important, gas tungsten arc welding (GTAW), also known as TIG welding, can meet those requirements.
But did you know proper shielding gas coverage is critical to achieving the best results in this process?
Many factors impact shielding gas coverage, including the choice of consumables paired with the proper gas flow settings.
Choosing the right gas and consumables for the job depends upon the desired performance and in some cases operator preference, among other key factors.
Keep these considerations in mind to get optimal results with GTAW.
What is the best gas for TIG welding?
In GTAW an inert gas protects the molten weld pool and tungsten from surrounding atmospheric gases. These atmospheric gases can react with the weld pool, causing contamination.
Although the primary purpose of a shielding gas is to shield the weld pool and tungsten from atmospheric gasses, the shielding gas also influences heat inputs and arc starting characteristics. *Due to the influence the shielding gas has on an arc, it is critical to adhere to any welding procedure specification (WPS) that is issued.
The three most common shielding gas options for GTAW are 100 percent argon, 100 percent helium and an argon/helium mix. You can use these shielding gases for all materials.
  • 100 percent argon: Welders use Argon for GTAW primarily due to its availability, cost and arc starting characteristics. Argon produces consistent high frequency arc starts due to its lower ionization potential and produces a more stable arc compared to that of helium.
  • 100 percent helium: Because it has higher thermal conductivity than argon, helium can be used for GTAW to produce higher heat inputs. These higher heat inputs result in faster travel speeds and higher depth-to-width ratios and are good for welding thicker materials. Helium does have a higher ionization potential, resulting in inconsistent arc starts.
  • Argon/helium: An argon/helium mix is typically used to achieve the higher heat inputs of helium while maintaining the superior arc starts offered by argon. These mixes commonly contain 25 to 75 percent helium. As helium content increases, the arc becomes hotter but high frequency arc starting performance and stability decrease.
To determine the best shielding gas for your application, consider the cost, required heat and high frequency arc starting consistency.
Gas flow rates
The optimal gas flow rate for TIG welding varies by the combination of consumables and atmospheric conditions. GTAW flow rates are typically between 10 and 35 cubic feet per hour (cfh).
When the shielding gas exits the nozzle, it has a different velocity than that of the atmospheric gases surrounding it. The different velocity and density between these two types of gases can cause currents to form, which can potentially turn the shielding gas column from a laminar flow (which is desirable) to a turbulent flow (less desirable). A turbulent flow can pull atmospheric gases into the shielding gas column, leading to contamination of the weld and/or tungsten.
As shielding gas flow rate is increased, the laminar flow column becomes more turbulent, increasing the chances for the weld and/or tungsten to become contaminated. Decreasing flow rate causes the shielding gas column to become more laminar and less turbulent. Although a higher flow rate produces a turbulent shielding gas column and isn’t necessarily better, a flow rate that is too low can be easily disturbed, breaking down the shielding gas column and potentially contaminating the weld and/or tungsten as well. To achieve the greatest laminar flow, use the lowest gas flow rate possible for the application and conditions.
Experts recommend a flow meter regulator for measuring cfh due to its accuracy. Place the regulator as close to the welding power source as possible for the best results and easy adjustments.
Gas lens or collet body?
Consumables used in GTAW include a nozzle and a collet paired with either a gas lens or a collet body. Consider the requirements of the finished weld when choosing between the two. If the weld is critical or requires high quality, a gas lens is the best option.
For non-critical or practice welds, a collet body is sufficient. Complete proper testing to verify that consumable combinations work for your application, and always follow the WPS.
A collet body has several holes that introduce the shielding gas to the inside of the nozzle. The holes tend to be perpendicular to the nozzle, causing the gas to spiral or be more turbulent exiting the nozzle.
When using a collet body, the tungsten should not extend outside the nozzle more than the distance of the inside diameter of the nozzle.
A gas lens improves the consistency of the shielding gas coverage and reduces turbulence compared to that of a collet body because it has several screens inside that produce a more uniform laminar flow. The gas lens allows the tungsten to extend farther than the inside diameter of the standard collet body.
Nozzle options
The nozzle, also called the cup, screws onto the collet body or gas lens and introduces the gas to the weld. Nozzles are available in various diameters, lengths and shapes to produce different shielding profiles or laminar flow lengths. Remember, a longer laminar flow is desirable.
As nozzle diameter increases, a longer laminar flow is produced. A smaller diameter nozzle with the same gas flow rate produces a more turbulent flow due to the gas velocity as it exits the nozzle.
Nozzle options include standard, long and extra-long. Longer nozzles provide longer laminar flow columns compared to shorter nozzles with the same flow rate and cup diameter. This is due to the flow being more developed before exiting the nozzle, reducing the shear between the flow and the surrounding atmosphere. Longer nozzles also allow for better access to tighter joints.
Nozzle shapes include straight, converging and champagne. Converging nozzles start with a larger diameter and neck and decrease to a smaller diameter. This shape is recommended to achieve the longest laminar flow. A champagne nozzle is the opposite shape of converging, starting with a smaller diameter and increasing to larger diameter. This nozzle is generally not beneficial, as the shielding gas exits at the gas lens or smaller diameter of the nozzle and does not disperse within the larger diameter before exiting.
To achieve the best laminar flow, use a converging shape nozzle in the largest diameter and longest length practical for the job.
Best practices for success
In addition to making proper consumable and gas choices, following best practices can minimize common mistakes and improve success in GTAW applications.
  • When assembling the torch, tighten the collet body or gas lens before the back cap. If the order is reversed, the torch can take on atmospheric gases that result in contamination.
  • Missing or improper insulators can cause shielding gas contamination, so inspect insulators frequently.
  • Don’t use a green oxygen hose — typically used in oxy-fuel applications — to deliver shielding gas; it can increase gas contamination risk. A vinyl or braided rubber hose is acceptable in most applications.
  • A pre-flow of shielding gas helps shield the tungsten and weld area and initiate the arc start. A minimum pre-flow of 0.2 seconds is recommended.
  • Gas post-flow is also beneficial, assuring the weld is protected from atmospheric gases as the weld pool solidifies.  Hold the torch over the end of the weld until post-flow stops, to ensure coverage of the area.  Many people often overlook the fact that this gas is also shielding the tungsten from contamination as it cools – preventing poor arc starts on subsequent welds. Proper post-flow time in seconds is determined by dividing welding amps by 10. A minimum of eight seconds is recommended.
  • When running longer gas lines, the initial shielding gas released upon starting the arc will be a much higher flow rate. Decrease this by using shorter gas lines, or by increasing pre-flow time to purge the lines before arc start.
In GTAW applications, choosing consumables and using flow rates that produce the longest laminar flow can help you achieve success. These factors reduce the risk of weld contamination and allow greater extension of the tungsten from the nozzle for better weld access. Follow best practices for proper shielding gas coverage to help prevent porosity and other weld defects.
Published:
