TIG Software - MillerWelds
TIG Software Updates & Expansions
Download the most up-to-date, innovative software solutions for your TIG welder instantly to a memory card for enhanced performance.
By downloading TIG software, you are agreeing to the Terms & Conditions set forth by
TIG Solutions and Miller Electric.
Download and Installation Instructions [PDF]
Dynasty/Maxstar Series 210/280/400/800 and Syncrowave 210
Download Latest Software Update
(281090C effective Jan-26-18)
 In this update:
Combined previous Syncrowave 210 (301129L) and Dynasty/Maxstar 210/280/400/800 (301153V) software files.
Dynasty/Maxstar:
  • General bug fixes (280 Insight models)
Syncrowave 210:
  • No changes – Please refer to items addressed in previous revision changes.
Includes these previous revision changes:
Dynasty/Maxstar
  • Improved AC HF arc starting (210/280)
  • Fix for arc outages typically seen shortly after arc initiation (400/800)
  • Fixes for premature weld termination in automated applications (400/800)
  • Improvements to TIG Lift-Arc™ (210/280/400/800)
  • NEW STANDARD FEATURE - 4Tm ( Modified ) trigger method. (210/280/400/800)
  • NEW EXPANSION FEATURE - Adjustable Hot Start feature (activated via memory card with additional expansion download) (210/280/400/800)
  • Improve display feedback of voltage, current and meter hold (210/280)
  • NEW STANDARD FEATURE - Cooler operation modes and Cooler-On-Demand™ - turn cooler off during extended non-weld time and in stick mode (for capable models) (280)
  • NEW EXPANSION FEATURE - AC Independent (activated via purchased expansion memory card) (210/280)
  • Cooler Power deactivated in Stick modes (280)
  • Display indicator of [ACAV] as indicator of AC amperage (rectified average) (280)
  • Improved start characteristics for welding anodized aluminum (280)
  • Improvements to SMAW (stick) starts for select models (280)
Syncrowave:
  • Additional diagnostic checks when switching processes
  • Fix for errors resulting from fast power cycling
  • Modifications to MIG process menu
  • Spoolmate 150 compatibility (serial numbers after ME390001J)
  • AC frequency adjustment (serial numbers after ME390001J)
  • DC pulse range expanded (serial numbers after ME390001J)
Expansions
Dynasty/Maxstar Series 210/280/400/800 Hot Start Adjust
Allows adjustment to process Stick’s Hot Start Time.
Download Expansion >>
(301416 effective Feb-21-17)
Don’t miss out on a great opportunity to receive information on new technology and software updates for your TIG welding equipment.
Register Your Product now to stay connected!
