Engine Driven Welders incorporate a gasoline, diesel, or propane fueled engine to produce power for Stick, TIG, MIG and Flux-Cored welding. They are typically transported on a truck or trailer and are primarily used outdoors.
The enhanced Bobcat 200 Air Pak is a quiet, fuel-efficient all-in-one that maintains power capabilities in a compact, lightweight footprint and is backed by industry-leading reliability and performance.
The Fusion 185 delivers a smooth, stable arc from with hybrid technology utilizing either engine power or 120/240-volt utility power, providing a unique combination of versatility and productivity in a lightweight package.
For class 3 to 5 service truck operators looking to consolidate or improve reliability of their power equipment, the Bobcat 200 Air Pak Diesel is a quiet, fuel-efficient all-in-one that maintains power capabilities in a compact, lightweight footprint that’s backed by the industry-leading reliability and performance customers expect.
Reliable outdoor power! Great for farm, ranch, maintenance and hobbyist.
Reliable engine-driven welders with unbeatable arc performance, providing the smoothest, most stable arc in the industry.
For work truck fleet managers looking to keep idle time off of their class 3 to 5 trucks, EnPak A30 is the quietest and most fuel-efficient All-In-One that maintains PTO driven power capabilities, including 12V DC, in a compact, lightweight solution backed by industry leading reliability and performance expected from Miller.
Powerful all-in-one tool designed for repair and construction with multiprocess weld quality, auxiliary power, air compressor and battery charge/crank assist.
Cost-effective, multiprocess engine-driven welder primarily used for Stick welding and auxiliary power. Great for farm, ranch, maintenance/repair operations and as a stand-alone power source.
Reliable, easy to use and more capable engine-driven welder great for stick and flux-cored welding. Designed for maintenance/repair operations, construction, farm, ranch and auxiliary power use.
Rugged engine-driven welder is great for Stick and Flux-Cored welding and designed for maintenance/repair operations, construction, farm, ranch and auxiliary power use.
Designed for farm and ranch owners in need of single and three-phase power to run 480 volt three-phase pivot irrigation systems. Provides additional auxiliary power for the farm and ranch.
Designed with the professional in mind, the Big Blue 400 Pro is the best for ease of use, reliability and fuel economy.
Next-generation, rugged, low-speed diesel engine driven welder designed for the transmission pipeline contractor.
The Big Blue 450 Duo CST is a rugged, compact, fuel-efficient diesel engine driven welder that provides 2 superior arcs in one economical package.
Clean, quiet, Multiprocess machine delivers up to 500 amps of welding power with an EPA Tier 4 Final compliant engine ideal for heavy-use.
This EPA Tier 4 Final 600-amp engine driven welder tackles tough jobs that require high-output for welding, gouging and auxiliary power.
For field-based work that requires single-operator power for welding, carbon arc gouging, auxiliary power, or running an air compressor to perform critical repair and maintenance functions, the Big Blue 600 Air Pak is the most reliable, versatile machine available to keep your worksite equipment fully functional and make you more productive throughout the day.
A complete multi-process & multi-operator engine driven welder that delivers two independent pipe quality arcs in one complete package. Equipped with ArcReach® technology, operators can change weld settings from the ArcReach feeder or remote. RMD® & Pulsed MIG welding capabilities are added with the ArcReach Smart Feeder.
Our most powerful Air Pak offers dual-operator productivity and Multiprocess flexibility. The clean running EPA T4i & T4F compliant engines reduce emissions.
For work truck fleet managers who want to take idle time off their trucks and insist on the most trusted and highest quality products, the new EnPak® A60 is the all-in-one solution that can be integrated into more of their fleet, delivering more capabilities for Class 5 and above truck configurations.
