EN 379 (European standard for welding helmets)
The European Norm (EN) that governs auto-darkening welding helmets in Europe incorporates alternative ratings for optical clarity that are not required in the USA. These optical clarity ratings via the EN 379 standard measure the quality of the light from the welding cartridge, as well as scattered light from the cartridge's layers. Rating tests occur across four classes of optical clarity1 (x/x/x/x):
- How distorted is the welding lens?
- How uniform is and how many impurities are in the welding lens?
- How consistently dark is the welding lens?
- How consistently clear and dark is a welding lens when looking at the arc at a sharp angle?
Helmet ratings are graded across those four rating classes from 3-1, with 3 being the lowest rating and 1 being the highest. The ratings are typically shared as x/x/x/x (e.g., 1/1/1/2). These optical clarity ratings only rate one qualitative aspect of a welding lens and are separate from required ANSI welding helmet ratings.
What is (and is not) important when it comes to optical clarity ratings?
Light is imperative to seeing the job at hand and doing that job well. You could have a lens that is as clear as crystal, but if there is not sufficient light you still will not be able to see clearly, and it can also cause eye fatigue.
If you want to find the welding helmet that truly gives you the best clarity in the U.S.:
- First, look for a helmet with the highest percent clarity rating within the safe limits of the light transmittance test in the ANSI Z87.1 standard when the lens is in the light and dark states.
- Second, ensure that your environment is well lit. If it is not, utilize lighting solutions either integrated into the welding helmet or stand-alone to improve visibility.
- Third, ensure you are using high-quality, ANSI manufacturer-certified magnifying lens and cover lenses to get the clearest view.
- Lastly, if provided, look for the optical clarity ratings with the EN standard. The first three (1/1/1/x) are most important because they directly impact welding 100% of the time. The fourth rating (x/x/x/1) is less prevalent in welding operations because the difference is hard to notice and only applies at extreme viewing angles.
In a perfect world, a welding lens would achieve the highest clarity ratings in both U.S. & EN standards. In practice, if you target perfect EN optical clarity with the fourth rating (1/1/1/1), you sacrifice up to 50% reduced visibility as benchmarked by ANSI light tests. This means manufacturers and welders must currently choose between the two standards and cannot meet the highest optical clarity benchmarks in both.
Since visibility is a priority for all welders, it is clear why experts in the U.S. do not require the EN optical rating and why 1/1/1/1 is not the best visibility rating. A welding helmet with EN 1/1/1/2 rating can have 2X better clarity benchmarked under Z87.1 compared to leading 1/1/1/1-rated helmets. There is no need to sacrifice up to 50% of your visibility when technology innovation provides it all with ClearLight® 2.0 Lens Technology.
