Deltaweld® Systems with Insight Centerpoint™ Solutions
DELTAWELD SYSTEMS ARE NOW AVAILABLE WITH THE INSIGHT CENTERPOINT WELD INFORMATION APPLICATION
- Deltaweld 350 and Deltaweld 500 power sources with the Insight Centerpoint application can help solve manufacturing challenges.
- Two Insight Centerpoint modes are available on Deltaweld Systems with Intellx™ Elite wire feeders: basic mode and premium mode.
June 2023
Digital Infinity™ Honor™ Helmet
- Largest viewing area (13.4 square inch) maximizes visibility — featuring ClearLight™ 2.0 Lens Technology.
- With every Honor helmet sold, Miller will donate $10 to Semper Fi & America’s Fund.
June 2023
FILTAIR® 215 High-Vacuum Fume Extractor
INDUSTRIAL SYSTEM DESIGNED SPECIFICALLY FOR WELDING
- Ideal for fabrication and manufacturing environments where versatility is needed.
- System provides fume capture at the source using multiple fume guns and attachments simultaneously.
- Learn more at: MillerWelds.com/high-vacuum-fume-extraction
April 2023
Miller® Copilot™ Collaborative Welding System
ENTRY-LEVEL COBOT WITH ADVANCED CAPABILITIES
- Entry-level cobot with advanced capabilities designed for shops and welders new to robotic welding
All-Miller system with a welder-centric design that removes complexity and makes it easy to handle quick changeovers for high-mix, low-volume part production
AccuGuide™ Precision Joystick simplifies precise torch positioning and adjustment with easy, fingertip control
IntelliSet™ Weld Settings Assistant takes the guesswork and complexity out of weld settings
February 2023
XMT® 650 ArcReach® Systems
SINGLE SYSTEM FOR WELDING AND GOUGING
- Operators can make process changes at the wire feeder without a control cable
- Configurations available for field and shop applications, with remote polarity-reversing (PR) power source and non-polarity-reversing power source models
- Operators get complete control, even hundreds of feet away from the power source, and they can switch between welding and gouging with the push of a button
February 2023
'22 Custom Kindig-it Design
DIGITAL INFINITY™ SERIES WELDING HELMET
- Dave Kindig’s handcrafted design featuring his most iconic car builds
- Largest viewing area maximizes visibility, featuring ClearLight™ 2.0 Lens Technology
January 2023
HIGH-DEFINITION OPTICS
- Provides high-definition optics for the most realistic view that’s clearer and brighter — before, during and after every weld
- Now available with Digital Infinity™, Digital Performance™, Digital Elite™, and T94™ Series welding helmets
September 2022
Hercules™ Welding System
AUTOMATED MIG WELDING SYSTEM
- Single-wire, high-deposition, automated MIG welding system
- Significantly boosts productivity rates without the expense of adding more weld cells
- Up to 30% more deposition rate and corresponding productivity gains
- In many cases, doesn’t require all-new welding automation, allowing operations to use equipment already in place.
August 2022
Hard Hat PAPR with T94iH-R™
INDUSTRIAL RESPIRATORY PROTECTION
- MSA V-Gard® Hard Hat Cap provides a unique profile with a V design to deflect objects and provide added protection in the event of impact
- Lift-t-talk head assembly improves communication, allowing operator to have access to face without removal of the head assembly
- ClearLight™ 2.0 lens technology provides advanced high-definition optics for the most realistic view that’s clearer and brighter — before, during and after every weld
- HDV Technology — found in the one-piece cover lens and grinding shield — provides a high-definition view at any angle with minimal distortion
- Gen. 2 blower assembly features three air speeds and an LCD display, which allows users to see fan speed, filter timer, battery level and current time
August 2022
Reimagined Dynasty® TIG Welder
FLEXIBILITY TO WELD MORE MATERIALS
- Simple setup allows for easy navigation through an informative color LCD display.
- Display features dynamic on-screen images showing how parameter adjustments will affect the weld.
- Increased access to the machine's full capabilities means shops can take on more complex projects, maximizing revenue opportunities.
July 2022
