XMT® 650 ArcReach® Systems | MillerWelds
Multiprocess
Reach for next-level productivity, cost savings and power.
Take Construction Welding to the Next Level
When you need durability, efficiency and control, our built-to-last Miller®XMT®650 ArcReach®power sources and ArcReach®16 wire feeders get the job done.
Check out exactly how many hours you could take back in your year with one of our systems.
welder welding outside on a construction site and welder welding inside in the dark
Change Your Workday With Next-Level Productivity
Walking to a power source doesn’t just waste time — it opens operators up to safety risks too. Now operators can change processes and polarity right at the wire feeder.
hand turning dial icon
Complete Control, Anywhere
You can take charge of your power source from hundreds of feet away — without the control cable.
hand pushing button icon
Easy Process Switching
When you need to switch between welding and gouging, just push the button. No swapping leads or trips to the power source.
polarity selection icon
Polarity Selection
When paired with the XMT 650 ArcReach Polarity Reversing machine, choose electrode-positive or electrode-negative self-shielded wire right where you are.
Take a Look at the Next Level
money symbol icon
Boost Your Bottom Line With Next-Level Cost Savings
Utilize new technology to drive down expenses. Our ArcReach Systems are built to keep your money where it belongs — with you. Dual capabilities mean you can weld and gouge with one machine. Plus, we have systems available with a ready-to-use wire feeder cart or sled.
lightning bolt icon
Strengthen Your Capabilities With Next-Level Power
Upgrade your technology for a new generation. With an optimized gouge process rated for 3/8" carbon, you have the industry-leading ability to move more material per pass. Cable Length Compensation (CLC™) ensures you maintain consistent weld quality.
Videos
