DIY Welding Project: TIG Rod Storage Rack | MillerWelds
DIY Welding Project: TIG Rod Storage Rack [Guide]
Share
Follow these instructions to build a storage rack to keep all your TIG filler metal clean and organized.
SKILL LEVEL: Beginner
TIME COMMITMENT: 3–4 hours
Here's what you'll need to get started.
TOOLS AND MATERIALS
.063 3003 alloy aluminum
1" PVC pipes cut to 36" length (12) and end caps (24)
Multimatic® 220 AC/DC multiprocess welder
1/16" 4043 filler metal
Stomp shear, band saw or reciprocating saw
Hole punch or hole saw & 1/8" drill bit
Drill or drill press
Sheetmetal brake or bending tools
WARNING: READ AND FOLLOW ALL LABELS AND THE OWNER'S MANUAL.
STEP BY STEP
Operator cutting sheet metal with a stomp shear in a shop
STEP ONE:
Cut your top piece to 5-1/2" x 29", or whatever measurements work for your workbench. My Miller ArcStation is 29" deep so I cut the bottom piece to 4" x 29".
Fabricator making marks on metal piece along ruler
STEP TWO:
Starting with your top piece, center 12 holes for the PVC pipe 1-5/8" from the long edge. Then, starting 3-1/2" from the short end, mark a hole every 2". The 12th hole should land at 25-1/2".
Welder marking measurement on sheet metal
STEP THREE:
Do the same on the bottom piece, but holes should be 2-1/8" from the long edge.
Welder tracing circle outline onto metal piece
STEP FOUR:
Because I’m using a Rotex punch to make my hole instead of a standard hole saw, I made a 1-3/8" circular template and centered the template around each mark to outline the outside PVC diameter. Punch out the holes.
Operator bending piece of sheet metal
STEP FIVE:
Taking the top piece, create two 1", 90-degree bends on the front side and a 1/2", 90-degree bend on the back edge.
STEP SIX:
The bottom piece will get a 1/2", 90-degree bend on the front and a 1", 90-degree bend on the back.
Operator drilling small holes in metal piece
STEP SEVEN:
In front of each large hole, drill two 1/8" holes through the top and 1" bend underneath, approximately 1/2" from the edge.
Metal pieces with marked measurements sitting on work bench
STEP EIGHT:
Create two gusset-style sides for the top. Start with two 4-1/2" x 4” pieces. You’ll need to create a 1-1/2" bend on your 4” side; but first, cut 1/2" x 1-1/2" off the top of the side. Then on the other topside corner, measure down 1” from the top and cut the bottom corner off between the 1" mark and the 1-1/2" mark for the bend. You’ll do the same on the other piece, just mirrored.
Close-up of welder TIG welding pieces together
STEP NINE:
TIG weld gusset sides to your top rack.
Operator holding metal gusset
STEP TEN:
For the bottom gussets, you’ll need two 3" x 4" pieces with a 1-1/2" 90-degree bend on the 3" side. Weld to the top of the bottom rack.
Operator cutting PVC pipes in shop
STEP ELEVEN:
Cut your PVC pipes to between 35" and 35-1/4" long. Clean and deburr the ends.
Split image of rack being bolted to workbench and PVC pipes being hammered into place
STEP TWELVE:
Mount the rack to your weld bench. Leave just enough room beneath the bottom piece to slide the PVC caps under. Use a rubber hammer to seat the PVC pipes tight into the bottom caps.
On top caps, sand the inside to make them slip on and off easier. Drilling a small hole on top also helps eliminate a vacuum inside tubes.
STEP THIRTEEN:
On top caps, sand the inside to make them slip on and off easier.  Drilling a small hole on top also helps.
About Andy Weyenberg
Andy Weyenberg headshot
Andy Weyenberg began welding at his father’s business a few years before joining the Army. After going to school for Electro-Mechanical, he started working for Miller Electric Mfg. LLC as a technical service rep and training instructor. Andy has built and raced stock cars since he was a teenager — and now builds high-performance street vehicles while also managing the Miller motorsports program.
Published:
