3. Ongoing procedure controls/recommended practices
Cooling of equipment
All operators should understand the duty cycle of the equipment they are using. Duty cycle is based on the number of minutes out of a 10-minute time period an arc welding machine can be operated at its rated output. An example would be 60% duty cycle at 300 amps. This would mean that at 300 amps, the machine can be used for six minutes and then must be allowed to cool with the fan motor running for four minutes.
Preparation of shielding gas hoses
The welding operator should purge the gas hoses to expel all air and moisture condensation from lines before welding. Porosity in the weld bead and poor bead color can result from entrapped gas impurities in the line. Condensation or loose fittings in the gun or TIG torch can also cause porosity in the weld bead, as can a defective gas hose or loose hose connection. These should be checked often.
Proper safety procedures or operator maintenance
Arc rays and eye protection
Arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Any exposed skin can be burned quickly by these rays. Welding helmets should be fitted with a proper filter shade to protect the operator's face and eyes when welding or watching, and approved safety glasses with side shields must also be worn. Screens or barriers to protect others from flash and glare should be installed where appropriate and maintained.
Clothing
Gloves and clothing should be flame-resistant. Clothing made from a dark-colored, tightly woven material is best suited for welding. Gauntlet-type leather gloves should be worn to protect the hands and wrists. Shirt collars and shirt cuffs should be buttoned, and open front pockets are not advisable as they may catch sparks.
Also, operators should never store matches or lighters in their pockets.
Pants cuffs are not recommended, as they will also catch sparks. Tennis shoes do not qualify as proper foot protection. High-top leather shoes or boots are necessary.
Environment
The area around the welder will be subjected to light, heat, smoke, sparks and fumes. Permanent booths or portable partitions can be used to contain light rays in one area. The heat and sparks given off are capable of setting flammable materials on fire. Therefore, welding should not be done in areas containing flammable gases, vapors or liquids or in dusty locations where explosions are possible. Metals with plating, coatings or paint that come near the region of the arc may give off smoke and fumes during welding.
Breathing welding fumes and gases can be hazardous to your health. Ventilate the work area and/or use local forced ventilation at the arc to remove welding fumes and gases. The recommended way to determine adequate ventilation is to sample for the composition and quantity of fumes and gases to which personnel are exposed. If in doubt, have an industrial hygienist test the air in your facility to ensure adequate protection from contaminants in your environment. For occupational use applications, employers must implement a written respiratory protection program meeting the requirements of OSHA 29 CFR 1910.134 (USA) or CSA Z94.4 (Canada), and other substance specific requirements as applicable.
When welding in confined spaces, such as inside tanks, large containers or compartments of a ship, toxic fumes may accumulate. Also, in an enclosed room, breathable oxygen can be replaced by shielding gases used for welding or purging. Work in a confined space only if it is well ventilated or while wearing an air-supplied respirator. Always have a trained watchperson nearby. Welding fumes and gases can displace air and lower the oxygen level, causing injury or death. Be sure the breathing air is safe.
General schedule for routine maintenance of engine-driven welders
8 hours
- Wipe up oil and fuel spills immediately
- Check fluid levels (oil and fuel)
- Service the air filter (refer to engine manual for specifics)
50 hours
- Service air filter element (refer to engine manual for specifics)
- Clean and tighten weld terminals
100 hours
- Change oil
- Change oil filter (refer to engine manual for specifics)
- Clean and tighten battery connections
- Clean cooling system (refer to engine manual for specifics)
200 hours
- Replace unreadable labels (order from parts list)
- Replace fuel filter
- Check valve clearance (refer to engine manual for specifics)
250 hours
- Check and clean spark arrestor
500 hours
- Tape or replace cracked cables
- Clean/set injectors (refer to engine manual for specifics)
1,000 hours
- Blow out or vacuum inside equipment. During heavy service, do this monthly.
Welding equipment maintenance and safety
By following a regimen of appropriate and thorough maintenance and safety, a good welding power source from a major manufacturer can run dependably for decades. Designed to withstand rough use, these machines typically use high-quality components and are tested for durability and reliability. For more information on welder maintenance or for the Miller distributor/service center nearest you, call 1-800-4-A-MILLER (1-800-426-4553).
