Work truck solution for CAT dealer — at a glance
Customer:
Carlos Pineda is a heavy equipment service mechanic contracted by Peterson Tractor Company (CAT) of San Leandro, California. He services and repairs the machines that keep the operation running at Waste Management’s landfill in nearby Fremont.
Challenge:
Powering his tools using a PTO-driven system required Pineda to constantly idle his truck engine. This significantly increased the number of hours on the engine and added wear and tear on the engine and drive train. The constant idling also used more fuel and increased jobsite noise.
Solution:
Pineda switched to an EnPak all-in-one solution from Miller and completely changed the way he uses his work truck. Pineda reports the EnPak solution reduced fuel usage, engine idle hours, and truck wear and tear.
- Pineda’s primary tool is often an air compressor, which he uses to run impact wrenches and other pneumatic tools. Consistent performance from the EnPak rotary screw air compressor lets Pineda work without wasting time waiting for the air to build back up. And he uses the air compressor and hydraulics at the same time without slowing down.
- The EnPak lets Pineda power his work lights, battery chargers, laptops and other electrical tools on the jobsite. And he can do all of this with the work truck engine turned off.
- Truck engine idling is eliminated, so Pineda’s jobsite is more comfortable since the noise is significantly reduced. An improved jobsite environment can benefit productivity and efficiency, since mechanics work almost entirely off the back of their trucks.
- The EnPak control panel makes life easier and safer on the jobsite. Pineda no longer has to climb into the truck to start equipment or adjust settings.
Results:
“It’s very fuel efficient. And with the truck shut off, there’s not any hours being put on the engine or the transmission. That extends the life of the component two or three times longer than if you had to run them all the time.” — Carlos Pineda
“Our truck idling time to run tools is close to 50 percent. Eliminate that and you’ll have substantial savings on truck engine life and fuel. And it will help us meet the ever-tightening emissions regulations on idling trucks put in place by California.” — Jack Ravazza, general service manager for Peterson Tractor
Discover if an EnPak power system is right for you.
Avoid downtime on the jobsite
Life in the landfill is hard on equipment. The constant pushing of garbage and dirt puts a heavy strain on the hydraulics and drive train of large bulldozers. Compactors take a constant beating to prepare the trash to be covered. It’s a dirty, harsh work environment that’s tough on equipment. It’s a job that cannot afford any downtime. If the trash isn’t covered by the end of the workday — a legal requirement — no one goes home until it is.
The same can be said about a heavy equipment service mechanic like Carlos Pineda. Pineda, the resident mechanic contracted by Peterson Tractor Company (CAT) of San Leandro, California, spends every day servicing and repairing these machines at Waste Management’s landfill in nearby Fremont. Pineda typically runs his tools — air compressors, generators and a hydraulic crane — off of a truck’s PTO. This puts wear and tear on its diesel engine and drive train. The PTO requires the truck to constantly idle, which puts a significantly higher number of hours on the truck’s engine compared to just driving it to and from the worksite.
Recognizing the need for a better solution to power equipment on a mechanic’s trucks, Miller introduced the EnPak power system. This completely self-contained air compressor, hydraulic pump and generator that runs off its own diesel engine. This eliminates the need for a PTO on a mechanic’s truck and allows these tools to work without running the truck’s engine. Pineda says EnPak made his truck more fuel efficient, reduced his truck’s engine hours and improved the operating environment around his truck.
Improved performance helps machines run faster
“A downed machine leads to the garbage not getting pushed, compacted, or covered,” says Pineda. “In the operation of a landfill, those are three very important factors. The garbage cannot stay exposed overnight. Waste Management runs into overtime costs if the shift ends and the garbage isn't covered. When machines are down, it costs them money.”
For a heavy equipment mechanic like Pineda, his workshop is completely mobile. The typical mechanic’s truck includes an air compressor, a hydraulic crane, a generator and a welder, plus all the other tools required to do the job: impact wrenches, grinders, lights, a computer for diagnostics, etc. Each truck travels to and from the jobsite daily and then idles all day as the mechanic powers this equipment off the truck’s PTO. With the introduction of EnPak, Pineda has completely changed the way he uses his truck.
“What I like the most about EnPak is that my truck doesn’t run now as I work. There’s no wear-and-tear on my truck. I don’t put a bunch of hours on it just by idling and burning fuel for no reason, polluting the air. EnPak puts out a minimum amount of exhaust, a minimum amount of noise and it powers all of my components as if the truck was running.”
Air compressor, hydraulics, generator power
The primary tool of any heavy equipment mechanic is an air compressor used to run impact wrenches and the carbon arc gouging capabilities of his welder. Pineda claims that EnPak gives him more consistent air compressor performance than the old compressor he ran off the truck’s PTO.
“I like the fact that the air compressor gives me on-demand air,” says Pineda. “I can run my big heavy guns and not have to wait for the air to build back. With the old system, I could undo one or two fasteners at a time and then have to wait for the compressor to build air back up. If there are 30 bolts and I have to wait a minute to take each bolt off, that’s a half-hour wasted. EnPak produces such a volume of air that I can run my gun without stopping. It’s very productive.”
“EnPak lets me use both air and hydraulics at the same time without slowing down,” says Pineda. “Sometimes I need to use my crane to support a piece when I’ll be using my impact gun to remove fasteners, and that all comes into play when you are disassembling a large machine.”
Another key tool for any mechanic is a generator. On many mechanic’s trucks, this is taken care of by a welding generator or a stand-alone generator. EnPak eliminates the need for either of these by producing 6,000 watts of power that can run welders and other power tools.
“I use the generator mostly for running big hydraulic rams or when I need a lot of psi to run a track press,” says Pineda. “It runs the pumps without stopping or slowing down. I use it for my drop lights, my drills. I’ve also used it to run a welder.”
Easier to work, easier to operate
Another key benefit of EnPak is a substantially-improved operator environment. Mechanics work almost entirely off the back of their truck. The loud noise of a running truck combined with the noise of running tools and the truck’s exhaust creates a mix of distractions for the mechanic. Tests have shown that EnPak reduces jobsite sound levels by as much as 10 decibels. And a vertical exhaust forces fumes up and away from the work environment (in addition to eliminating the truck’s exhaust).
“If you’re working around high decibels, it puts a stress level on you that should be avoided,” says Jack Ravazza, general service manager, Peterson Tractor. “I think reduced noise can have a big effect on the performance of a technician. The better the environment, the more productivity he is going to have.”
“With the older setup,” says Pineda, “If you had to lie down anywhere near the equipment, you would have the muffler pointed at your face and it would be gassing you the whole time you had to work. So then you’d park your truck in a different direction away from the equipment you were working on, which is inconvenient. Now, with EnPak, the exhaust is diverted up and I don’t even smell it.”
Remote panels
The integrated control design also makes life easier on Pineda by providing all of the controls he needs right at the back of the truck.
“The EnPak remote panel lets me start all the functions from the back of the truck without having to go and climb into my cab, turn the PTO on, then climb back out and start working. I can just go right to the back panel, start the component and I’m ready to work.”
The remote panel also monitors, operates and provides diagnostics for engine and air compressor functions such as fuel usage and engine rpm. And Pineda didn’t have to learn any new controls as the integrated design allows him to use the crane remote he is already familiar with.
“I didn’t have to learn anything new,” he says. “Within five minutes I was running EnPak and all my tools like nothing had changed.”
Fuel and engine wear reduced
EnPak is completely integrated into the fuel and electrical systems of Pineda’s truck. Now he only has one tank to fill up in the morning compared to the two tanks he used to fill up every day (truck and engine-driven welding/generator). Because it runs with the truck turned off, it lowers fuel use by as much as 30% and can reduce truck engine hours by as much as 60%.
“I can honestly say that I hardly see any fuel use,” says Pineda. “I can start out with a quarter-tank of fuel in the truck, run EnPak for two or three hours, and the needle on the fuel gauge hasn’t moved. It’s very fuel efficient. And with the truck shut off, there’s not any hours being put on the engine or the transmission. That extends the life of the component two or three times longer than if you had to run them all the time.”
For Ravazza — whose job it is to make sure Peterson Tractor’s customers’ needs are being met both through tooling and manpower — he sees an obvious value to the reduced wear on the truck and the savings it provides equipment service departments.
“Our truck idling time to run tools is close to 50 percent,” he says. “Eliminate that and you’ll have substantial savings on truck engine life and fuel. And it will help us meet the ever-tightening emissions regulations on idling trucks put in place by California.”
