Welding Stainless Steel Tube and Pipe: Maintaining Corrosion Resistance and Increasing Productivity | MillerWelds
Share
Altering established methods can help maintain quality levels and lead to significant productivity enhancements in stainless steel pipe welding applications.
(Reader's Note: As originally seen in The Welding Journal (American Welding Society)).
Welding stainless steel tubing and pipe
There’s no voodoo when it comes to welding stainless steel tube and pipe. Proper selection of filler metals, joint preparation, cleanliness and welding processes help ensure the final product meets the designated quality standards and retains its intended corrosion resistant qualities. However, evolutions to well-established processes and techniques allow pipe fabricators to increase productivity without sacrificing the corrosion resistance of the stainless steel.
This article will cover the basics of welding stainless steel tube and pipe for applications ranging from high purity food and beverage, pharmaceutical and petrochemical pipe to oil and gas applications. Within those basics, we will present best practices and new wrinkles on established methods that may help drive productivity in your shop while improving or maintaining the desired corrosion resistance.
As a note: critical applications where processes are certified should not be altered without going through appropriate certification processes. Each process detailed in this article has been certified in critical applications. It is meant to spur ideas as to how to move your own welding practices forward.
Filler metal selection critical in controlling carbon levels
Selecting filler metal for stainless steel pipe is about enhancing the properties of the weld and meeting the application's requirements. Filler metals with an “L” designation, such as ER308L, provide a lower maximum carbon content. This can help retain corrosion resistance in low carbon stainless alloys. For example: if you weld a 304L base metal with a standard 308 filler metal, you’ll actually raise the carbon content of that joint and increase the chance of corrosion. In high purity applications – food, beverage, pharmaceutical – that low carbon content is critical for maintaining corrosion resistance. Conversely, a filler metal with an “H” designation provides higher carbon content for applications requiring greater strength, particularly at high temperatures. Filler metals with higher silicon levels, such as ER309LSi, increase weld puddle fluidity, improve tie-ins and increase travel speeds for greater productivity. The 309 series filler metals are also particularly adept at joining dissimilar stainless steels and in overlay applications.
When welding stainless steels, it’s also important to select a filler metal with low trace (or “tramp”) elements. These are residual elements in the raw materials used to make filler metals. They include tin, antimony, arsenic, phosphorus and sulfur, and can have strong effects on corrosion resistance.
Controlling sensitization with filler metals, interpass temperature control
Sensitization is the primary cause of the loss of corrosion resistance and is affected by the chemistry of the base material and filler metal, as well as the temperatures at which the weld cools. Chromium oxide is the “stainless” layer of stainless steel. If you raise the carbon levels in the weld and neighboring heat affected zone, it forms chromium carbides, which tie up the chromium, preventing the formation of chromium oxide. This in turn allows the steel to corrode or it will not have the intended corrosion resistance.
There are three ways to combat sensitization: the first is to use a low carbon base and filler metal to reduce or eliminate carbon. This method, however, is not always practical as carbon is a vital alloying ingredient in some applications.
The second is to minimize the time the weld and heat affected zone spend at temperatures conducive to sensitization. A general consensus puts that temperature range between 500- and 800-degrees Celsius. The shorter the time spent in that temperature zone, the less damage that accrues from the heat of welding. As such, it is important to adhere to maximum interpass temperatures identified in welding procedures. The goal in multi-pass applications should be to use as few passes as possible and weld at the lowest heat input possible to achieve faster cooling.
The third is to use filler metals with special alloying ingredients to prevent the formation of chromium carbides. For instance, titanium and niobium can be alloyed into the filler metal and help prevent reactions between chromium and carbon. These elements also have strong effects on strength and toughness, limiting the applications in which they are useful. They also do not provide any benefit to the areas farthest away from the weld in the heat affected zone.
Shielding gas critical in retaining corrosion resistance
Welding stainless steel tube and pipe traditionally requires a back purge of argon. In non-critical applications, where cost is a driving factor, operations can also use nitrogen as a back purge. However, this may lead to the formation of some nitride compounds in the weld root, which sacrifices some corrosion resistance. This can be an acceptable trade-off in applications such as stainless steel piping for large compressed air systems and hydraulic fluid systems where water is not normally present inside the pipes and the risk of corrosion from the inside is low.
Experts recommend straight argon for gas tungsten arc welding (TIG) of stainless steel tube and pipe. Shielding gas selection for wire processes is more complicated.
Traditionally, MIG welding has relied on mixtures of argon and carbon dioxide, argon and oxygen, and 3 gas mixtures. These mixes usually contain mostly argon or helium, with carbon dioxide comprising less than 5 % of the total gas mix. That is because the carbon dioxide can decompose in the arc and contribute carbon to the weld pool, creating a sensitized weld vulnerable to corrosion. Pure argon isn’t used with the MIG processes because it doesn’t easily support a stable welding arc. Other trace constituents like carbon dioxide and oxygen can serve this role. Welders can only use argon and oxygen gas mixes to weld in the flat position because the oxygen creates a very fluid molten weld puddle. Welders can use argon/carbon dioxide in combination with pulsed MIG to weld in all positions, as well as Tri-Mix shielding gas mixtures.
Manufacturers design flux-cored wires for welding stainless steel to run on traditional 75/25 percent argon/carbon dioxide mixes. The flux ingredients prevent the carbon contributed by the shielding gas from contaminating the weld. Meanwhile, the fluxing action of the slag covering scavenges the excess carbon and keeps it from entering the weld deposit. Operations can successful weld 304 stainless steel using the Regulated Metal Deposition (RMD™) process without a back purge. This is not true for duplex stainless steels. These must be purged with an inert gas such as argon.
Weld preparation and the importance of fit-up
A discussion on welding stainless steel tube and pipe is not complete without a discussion on joint preparation. The normal trappings of welding stainless steel apply: use dedicated brushes, files and grinders that never touch carbon steel or aluminum. Cleanliness is critical. Even trace elements of foreign materials incorporated into the weld can cause flaws and lead to reduced corrosion resistance and strength.
Because stainless steel is so sensitive to heat input, how operations cut and bevel the pipe can also have a detrimental effect on the weld. Any gap or lack of fit-up requires the welder to add more filler metal and can slow the welding process down, leading to buildup of heat in the affected area. You want as close to perfect fit-up as possible, especially on sanitary and high-purity tubing.
Controlling heat input and speed drives process evolution
The welding process itself also plays a critical role in controlling heat input and cooling, and thereby corrosion resistance and distortion. Operations typically use TIG welding for welding stainless steel tube and pipe, and it remains the optimal solution for extremely high purity applications on tube or pipe at or below 6-inch diameter and schedule 10 wall thickness. The preferred method for high purity food-grade stainless steel is an autogenous TIG square butt weld. The ability to fuse the pipe without adding any filler metal helps keep heat down and eliminates any chemistry changes that could be created by the added filler metal. This practice typically works on any tube or pipe thinner than 1/8-in. thick. As the pipe gets thicker – in the schedule 10 to 40 range – then it becomes necessary to bevel the pipe and add filler metal. There are some smaller diameter pipes with thicker walls – such as 2-inch diameter schedule 80 – where TIG remains ideal because switching to a wire process on that small of a pipe diameter isn’t practical.
Today’s TIG inverters perform this application extremely well, as the pulsing capabilities have improved substantially since the days of the larger transformer-based machines and help to keep heat input down. Older TIG technology is limited to pulsing at about 20 pulses per second. Newer TIG inverter technology, such as the Maxstar® 200, allows high speed DC TIG pulsing up to 500 pulses per second. Having the ability to control pulsing up to that range allows the welder to reduce their average amperage and heat input significantly, helping to control penetration and reduce distortion. Pulsing at these higher frequencies increases the arc focus by pulsing quickly between a high peak and low background current. This allows welders to get more penetration, move faster, and reduce the heat-affected zone. Tests have shown that pulsing between 250 and 400 pulses per second increases travel speed up to 35% without sacrificing weld penetration.
Using MIG processes for welding stainless steel tubing
While there remain thicker high purity pipe applications that still require a TIG root and/or a TIG hot pass, MIG root passes on stainless steel are regularly certified in less critical applications and, in some cases, more critical applications traditionally performed with TIG. Some applications are even being completed without the assistance of a back purge. This is a relatively recent development made possible with a modified short circuit MIG welding process such as RMD available with the PipeWorx pipe welding system. Note, however, it should never be done in high-purity applications with duplex stainless steels such as pharmaceutical, semiconductor or food processing. A common welding sequence on a larger diameter pipe, such as a 12-inch schedule 40 pipe used in oil and gas processing, would be to lay an RMD root and then switch to a pulsed MIG (using the same shielding gas and wire as the root pass) or flux cored arc welding (FCAW) process for the fill and cap passes. This eliminates the need for a TIG hot pass.
RMD presents an improvement over traditional short-circuit MIG in that the welding system anticipates and controls the short circuit, then reduces the welding current to create a consistent metal transfer. Precisely controlled metal transfer provides uniform droplet deposition and makes it easier for the welder to control the puddle and, thus, heat input and welding speeds. The smooth metal transfer compensates for a high-low misalignment between pipe sections, forgiving imperfect pipe fit-up in some applications and creating more consistent root reinforcement on the inside of the pipe. Similarly, the shielding gas comes out of the gun relatively undisturbed by the controlled transfer and gets pushed through the root opening to prevent oxidation on the backside. This feature has allowed pipe fabricators to certify processes without a backing gas in some austenitic stainless applications. This completely eliminates the considerable time and cost associated with back purging larger pipes.
RMD is also easier to train new welders to use as the controlled metal transfer makes for an easier-to-control weld pool. The process also maintains a consistent arc length regardless of electrode stick-out and enables an excellent view of the welding puddle. In the search for skilled welders, these features take training down from weeks to a matter of days.
This process allows pipe fabricators to increase their speed and productivity without putting extra heat into the part – helping to maintain the corrosion resistance and mechanical properties provided by stainless steel. Welding speeds with this modified short-circuit process range from 6 to 12 inches per minute (ipm) versus 3 to 5 ipm with TIG welding. That speed increase, plus the ability to eliminate the TIG hot pass and potentially eliminate the backing gas in some applications, provides significant savings in time and cost.
The reduced heat input with RMD also helps with distortion on stainless steel compared to other MIG processes. Some companies report being able to take pipe fabrication processes that were previously modular – assembling in pieces and then bringing together later for full assembly to control heat input – and fabricate the whole structure now in one sitting because of the lower heat input and reduced distortion. This simplifies the process and allows it to come together more quickly, significantly reducing labor hours.
Published:
